OPT Question
Old Feb 10, 2009 | 07:27 PM
jlegger's Avatar
Default OPT Question
Old Polaris Tech,
Got a 2005 700 Sportsman that I am getting no power what so ever when I turn the key to start, no dash lights no starter nothing. However when I disconnect and reconnect the battery I can turn the key on and everything operates as normal. Turn the key off and I have to go thru disconnecting and reconnecting the battery to start again.
The atv had a recall on some type of electrical component and I had that replaced. Is there another electrical component I need to replace or take a look at.
thanks in advance for your help!
Old Feb 10, 2009 | 07:53 PM
I would recheck that all ground wires that they disconnected and reconnected on ecm module are tight first,if not could be causing problem. Look for any they may have forgotten to rehook up! Should be about 5 brown wires. Also sounds like thermal link cutting off and resetting.
Old Feb 11, 2009 | 06:28 AM
jlegger's Avatar
Thanks OPT that will give me a place to start!
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
