Bad swingarm bearings
Old Feb 11, 2009 | 03:49 PM
hummer93516's Avatar
Default Bad swingarm bearings
05 prairie 360 the back end is moving when i drive alittle bit not much. im guessing this is bad swing arm bearings? how long can i drive on bad ones?
Old Feb 11, 2009 | 07:55 PM
roscoe69's Avatar
its not a good idea to run on bad bearings, it could ruin the tube area where the bearing is held. this area is not replacable. the shaft is repairable but probably expensive.
think about sealing the area behind the bearing or making it greasable. there are olso seals on the shaft pieces i believe. do a search on this subject. its not that difficult to
work on.
wendal
Aug 3, 2024 10:03 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
jbrewster94
Sep 23, 2015 04:16 PM
