Warrior Intermitant Spark
Old Feb 11, 2009 | 07:56 PM
corbyzz's Avatar
Former Sponsor
Default Warrior Intermitant Spark
Alright guys here is one for you. New pick up coil installed, stator is good, parking brake and clutch sensor disconnected and this is what is happening.
When start button is pushed we have good blue spark on the first revolution, but once it is turning over good no spark. Good spark also on the last revolution of the motor.
Please help!!
Grounds have been checked and we have bi passed the starter relay.
Old Feb 12, 2009 | 06:43 AM
corbyzz's Avatar
Former Sponsor
any ideas?
Old Feb 12, 2009 | 07:31 PM
lucasislight's Avatar
I would check the Ignition coil and the CDI, both are possible culprits. I had the same issue with a bad CDI.
Old Feb 16, 2009 | 10:04 PM
Commonarcwelder's Avatar
I run into the same problem. It ended up being the ground to the CDI. I could stick a straight pin in the ground wire and run a jumper from it to the negative side of battery and it run fine. Then the strangest thing happened. While it was running the jumper came off and it started running bad, then straightened out. It has run awesome ever since!
Old Feb 18, 2009 | 07:59 PM
corbyzz's Avatar
Former Sponsor
talked to the guy at RM stator and he said that is most likely the stator, I ordered one are they any good?
Old Feb 19, 2009 | 01:37 AM
91Warrior357's Avatar
hmm no i havent heard of them but they seem like there an ok company, 1 year warranty, keep us posted on it though, alot of people buy ricky stators but ive heard alot of bad things with them, specially there banshee stators i heard they were horrible.
Old Feb 20, 2009 | 12:24 AM
beefy46172's Avatar
Loves To Ride!
I'd really seriously be leaning to the CDI box if you have checked and have good grounds all around.
Old Feb 22, 2009 | 05:27 PM
corbyzz's Avatar
Former Sponsor
Its alive, fixing your own stuff feels so good!!!!!
Old Feb 22, 2009 | 05:31 PM
thats awesome hopefully the rm stator lasts, i might be buying one also, lol
Old Feb 23, 2009 | 10:59 AM
dee-stroyer's Avatar
yeh i had the exact same problem with my warrior and sevice guys told me stator or coil. i spent 500-700 try to find the problem. turned out it was the cdi box. good luck.
