oil change
Old Feb 14, 2009 | 10:49 PM
blkedoutsprtsman's Avatar
Default oil change
Ive already changed the oil once in my machine(20hr) at the first service interval. Since i did not empty the sump on the engine, should i to be on the safe side before i go riding for the spring/summertime do it. I did everything else correctly as far as making sure there was vacuum in the oil lines when i was complete. I know that ive heard it is not necessary to dump the oil in the engine all the time, but should i do it every other oil change???? i want this machine to go a very long time and since i bought it new, it is in my hands to make sure i attain that goal.
Old Feb 15, 2009 | 10:43 AM
Spdecat's Avatar
Default oil change
You should drop the sump oil every time you do a oil change it only adds a few minutes if you don't your leaving dirty oil in you engine that will be mixing with the clean oil you put in . I would not worry about it this time but next time drop the sump oil too .
Old Feb 15, 2009 | 10:49 AM
Default oil change
<div class="FTQUOTE"><begin quote>Originally posted by: Spdecat
You should drop the sump oil every time you do a oil change it only adds a few minutes if you don't your leaving dirty oil in you engine that will be mixing with the clean oil you put in . I would not worry about it this time but next time drop the sump oil too .</end quote></div>
[img]i/expressions/face-icon-small-happy.gif[/img] DITTO!
Old Feb 15, 2009 | 11:00 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Default oil change
If you choose to use an aftermarket filter look at the wix 1358 or NAPA 51358 (wix makes the napa filter). Better filer and quite a bit cheaper. I use mobil 1 0w 40w instead of the polaris (overpriced) stuff.
You should empty the sump on your next oil change.
Old Feb 15, 2009 | 11:01 AM
weedy's Avatar
Default oil change
Old Feb 15, 2009 | 11:08 AM
Default oil change
<div class="FTQUOTE"><begin quote>Originally posted by: weedy
You should empty the sump on your next oil change.</end quote></div>
Polaris is NOT so overpriced as some may think! Just depends on your area,where you get it and such! Last time I checked Wallyword, Mobil 1 was higher than Polaris PS4 Plus! Again depends on where you can get it!
Old Feb 15, 2009 | 11:51 AM
DavidXP's Avatar
Default oil change
where is the sump located and how do ya dump that i personally have never done an oil change on my machine (36hrs) the dealer did the first one but from now on i will do it!
Old Feb 15, 2009 | 12:27 PM
DCT's Avatar
DCT
Banned
Default oil change
DavidXP,
Don't think your 850 has a sump to worry about. Dropping the drain plug and removing the oil filter should get all the old oil out. That's another feature about the XP over the older models, as that sump draining is a bit of a pain. My dealer recommends not even doing it.
Anyhow, check with one of the other XP owners to be sure.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
