03 grizzly
the front diff is leaking on my grizzly around were the front drive shaft goes in im looking for a site were i can print off the deractions on how to replace it or a site were i can order a repair manual
Sounds like the front driveshaft seal. Try this site
http://www.bikebandit.com/sem/...mc_id=685278&WT.srch=1
I don't see any after market manuals for sale yet. I guess you could get the factory service manual. If it is like my 05 Kodiak 450 then you will have to do a little bit of disassembly to remove the brakes and suspension parts. Then you grab the rotor and jerk it out of the front diff. Pull the seal and replace it and replace the circlip. A little grease on the seal and then carefully jam the shaft back in. Hook it back up and you are done. If it is like my 450 it is a easy job.
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
