are the ECM & rectifier the same unit?
Old Feb 17, 2009 | 01:42 PM
curby's Avatar
Default are the ECM & rectifier the same unit?
On a 2005 sportsman 500 ?if not wheres the rectifier located? thx mike..
Old Feb 17, 2009 | 02:13 PM
94harley's Avatar
it's integrated in the ECM which is located under the front panel under the headlight pod. There was a recall on them(several times) Your's may need done, it may have been done already. The vin needs ran to see if it applies.
Old Feb 17, 2009 | 04:24 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
It's called the Sure Power Industries............At least the factory one in 2006 was called that!!
What kind of trouble are you having?
......Caper...........
Old Feb 17, 2009 | 07:42 PM
<div class="FTQUOTE"><begin quote>Originally posted by: curby
On a 2005 sportsman 500 ?if not wheres the rectifier located? thx mike..</end quote></div>
Ecm controls charging and fan operation.
Old Feb 17, 2009 | 07:55 PM
Plus two Solid State Circuit Breakers for protection.....Caper......
Old Feb 17, 2009 | 10:17 PM
curby's Avatar
its not charging but the thing runs fine on a charged batt,utill it runs down.the obd shows its not charging. im checking all the connections with contact cleaner and re-dielectric grease the connections. any tip? thx mike
Old Feb 18, 2009 | 07:02 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
have a deasler run the vin# to see if the recall has been done. if not then you will get it fixed for nothing.
Old Feb 18, 2009 | 08:11 AM
curby's Avatar
it been in for the recall update
Old Feb 18, 2009 | 03:48 PM
Just remember on am on my third one........All replaced FREE!!
The recall one did fail on my Quad..........Caper.....
Old Feb 18, 2009 | 09:05 PM
curby's Avatar
How long after did it fail?its been 2 years on this one
