Warrior not starting
Old Feb 19, 2009 | 07:56 PM
yfs2020's Avatar
Default Warrior not starting
Hey,
I need help! Have a 99 warrior did a complete rebuild from ground up. I'm having electrical issues. Checked the continuity on the parts such as coil, selinoid relay, start switch. New parts for the key and both of the relays. I can arc the selinoid and start the quad but I cannot start with the button. Any ideas? If you need any additional info let me know.
Old Feb 20, 2009 | 12:21 AM
beefy46172's Avatar
Loves To Ride!
Solenoid almost for sure it sounds like. Try tapping on it and see what happens while starting. They run about $25 at the dealer and they come with a new mounting boot. Quick and easy swap out, and definitely sounds like the culprit in this case.
Old Feb 21, 2009 | 07:53 PM
yfs2020's Avatar
tried tapping on the solenoid and I still got nothing. I might buy one to be sure though. Any other suggestions?
Old Feb 21, 2009 | 08:30 PM
91Warrior357's Avatar
does it have a blown fuse? in the little pill shaped rubber boot, 20 amp fuse i think, see if its blown
Old Feb 22, 2009 | 08:10 AM
yfs2020's Avatar
I've replaced that whole piece with a brand new fuse.
Old Feb 22, 2009 | 09:12 PM
yfs2020's Avatar
I was wondering if the neutral switch off the block could cause this problem?
Old Feb 23, 2009 | 01:19 PM
beefy46172's Avatar
Loves To Ride!
Shouldn't, because you can always start regardless of your gear if the clutch is pulled in. I would take apart the assembly on the handlebars that holds your start button/kill switch and give it a good cleaning, and if that doesn't fix than I would say almost for certain it is the solenoid.
Old Feb 23, 2009 | 02:08 PM
yfs2020's Avatar
I have already cleaned the parts and ordered another solenoid. Just a waiting game now.
Old Feb 23, 2009 | 08:37 PM
abm1124's Avatar
hey i got the same problem i gotta use a screw driver and tap the solenoid to start mine i still havent fixed it but i think it has to do with the neutral safty switch but if u find out wut it is let me no or u let me no if u do its pissin me off
Old Feb 26, 2009 | 08:23 PM
yfs2020's Avatar
I'm still waiting but i'll let you know what I find out
