raptor not starting
Old Feb 23, 2009 | 05:51 PM
warrior405's Avatar
Default raptor not starting
i just bought a raptor 660 and the guy said he couldnt get it to start. i thought it was the solenoid because it was clicking really fast when you hit the start button. my friend had a spare one so we put it on and the same thing. we put some jumper cables on it and it took it a while but we finally got it started. i was wandering if it was the battery but it is fully charged(i took it to oreillys). what would cause it to crank slow and buzz. sometimes it will crank hard enough to start and sometimes it wont. could it be the starter itself?
Old Feb 23, 2009 | 07:26 PM
warrior405's Avatar
well i think its the solenoid. i shorted the solenoid with a screwdriver and it cranked right over.
Old Feb 23, 2009 | 07:36 PM
Sapper79's Avatar
Check the cranking amps on the battery just to be sure. I had to replace my battery. It showed 12+ volts on the meter and my charger showed it to be charged, but it had zero cranking amps when tested at the shop.
Old Mar 1, 2009 | 07:20 PM
warrior405's Avatar
im still kinda wandering if its my solenoid. the guy i got the raptor from said it was a new battery but who knows. i tested it and shows 12.8 volts but when i crank it its only like 7 volts. and if i try to jump start it the positive batt. cable going to the solonoid will smoke a little.do you think it might be a battery. now the solonoid wont just crank over when i short it with a screwdriver like it did at first.
Old Mar 1, 2009 | 07:25 PM
warrior405's Avatar
also i forgot to say that it cranks alot easier with the choke off rather than on. if its on it wont hardly crank when i have jumper cables hooked to it. maybe starter?also when i hit the start button the n/r/temp lights are really dim
Old Mar 1, 2009 | 08:11 PM
shreker08's Avatar
I would start with a new battery was the machine sitting outside it could have froze
Old Mar 1, 2009 | 10:11 PM
warrior405's Avatar
it was in a garage when i bought it
Old Mar 6, 2009 | 11:59 PM
warrior405's Avatar
well its not the battery, i took one of my friends battery of his out and it still did the same thing. do you think it might be the starter seizing up?
Old Mar 7, 2009 | 08:54 AM
91Warrior357's Avatar
seems like it could be a real poor connection or maybe something has corrosion somewhere, all the cables that leave and go to the solenoid take them out and see if theres white or green crap on the ends, if so i usually just cut the bad end off if i have enough cable, i usually use wd-40 to clean the connections then use dialectric grease when i fasten the stuff back together.
Old Mar 7, 2009 | 09:24 PM
JLsparky7's Avatar
Prolly the battery.
