2000 Honda 300 Fourtrax TRX Not starting/rolling
Old Feb 25, 2009 | 11:31 AM
Chainsaw9's Avatar
Default 2000 Honda 300 Fourtrax TRX Not starting/rolling
First of all, want to thank all who contributes to this board. I try to learn as much as I can before posting much, but I can't seem to find this problem yet.
My son has a 2000 Honda Fourtrax 300 2WD. We just recently purchased it from someone just "wanting it out of their way". He did tell us that the rear end was locked up, and he was right. The tank also has some rust in it, but nothing that has eaten through the wall. I have got a couple good ideas for getting rid of the rust from postings.
The when I jump battery, the solenoid pops (but thats all)and I think that is normal, but engine does not even try to turn over (it is in neutral). And when I try to kick start, I cant even begin to move the lever. Something is locked up and I am not sure whether it is the engine or rear end. The rear wheels will not turn at all.
Any suggestions are greatly appreciated! Thanks, Jeff
Old Feb 25, 2009 | 02:31 PM
Skatike27's Avatar
Can you spin the rear tires, if you lift up the fourwheeler? Also, how do you know it is in neutral? Does the indicater light come on the dash?
Old Feb 25, 2009 | 04:13 PM
Chainsaw9's Avatar
Hey, thanks for replying!
The rear wheels will not spin at all. I have lifted up and tried while bike in neutral. I hooked a booster to it and got lights on dash to light up. Only the green light stayed on, and it was for neutral.
Old Feb 25, 2009 | 05:12 PM
gambler_m_99's Avatar
I would start by removing the brakes from the rear end along with the bearing. If it is not one of those I would say it is in the tranny. Both are fairly easy to do before you spend alot at the Honda shop.
Old Feb 25, 2009 | 05:24 PM
Chainsaw9's Avatar
If the piston was seized up, it would not kick, right? Could the upper part seize and lock up the tranny as well? Thanks
Old Feb 25, 2009 | 10:39 PM
If it will kick over it is not the piston. Sounds like the tranny is the problem.
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
ScopeZ_
Jul 28, 2015 01:44 AM
