850 torque specs needed
Old Feb 25, 2009 | 12:23 PM
WOLF1's Avatar
Default 850 torque specs needed
Wondering if anybody has a manual for the 850? What I need is the torque specs for the cylinder head bolts. And are they a torque to yield bolt that needs to be replaced?
Thanks....Ray
Old Feb 25, 2009 | 12:26 PM
HIGHOCTANE's Avatar
I have one. I'll get you the info when I get home. Is the head bolts the only thing you need?
Old Feb 25, 2009 | 12:55 PM
WOLF1's Avatar
Thanks HO,
The specs for the head bolts is the most critical, but if you have them for the intake, valve cover, thermostat etc... that would be great.
Thanks!
Old Feb 25, 2009 | 12:56 PM
WOLF1's Avatar
Cam sprocket bolt would be another good one if possible.
Thanks.
Old Feb 25, 2009 | 12:59 PM
HIGHOCTANE's Avatar
I'll get 'em to you this evening...
Old Feb 25, 2009 | 01:01 PM
Rutcutter's Avatar
What cha' been doing wolf1 ? Power mods?
Old Feb 25, 2009 | 03:09 PM
WOLF1's Avatar
Oh, you know... a little of this and a little of that!
Old Feb 25, 2009 | 03:21 PM
HIGHOCTANE's Avatar
Ok...so far not impressed with the Polaris service manual,I've found a few discrepancies,and some, like this one are biggies..
There is a TQ chart in the begining of the Engine section that shows the TQ as 26ft lbs+ 90* for the head bolts...but the actual text procedure shows 43.5 ft lbs+90*??
It doesn't say what size the bolts are so you will have to use you judgement on that one. It may be obvious that one or the other is right....43.5+90* sounds reasonable for head bolts but it's hard to say without knowing what size they are.
Anyway here is the basic procedure...
The 6 main head bolts are wet torqued. Install the 6 main bolts finger tight then install the 2 outer 6mm bolts. Then,get this,you tighten the 6 main bolts snug,lol..no kidding that is what it says.. Then tighen them to 43.5ft lbs(59Nm) Then the next round is an additional 90*..sounds like you need new bolts huh? Even though the manual doesn't say that..
The TQ for the 2 small bolts is apparently standard TQ which is 72-78 inch lbs.
Sequence is:
Intake side
4---2---6
5---1---3
Exhaust side
Camshaft sproket bolt is 28ft lbs..says to tq after you install the chaing tensioner..
Thermostat 89 in lbs
Valve cover 89 in lbs..
IAFM is 18in lbs then 89 in lbs..
Old Feb 25, 2009 | 07:03 PM
WOLF1's Avatar
Hmmm.....
I think I'll order new bolts just to be safe.
The head bolts are 11mmx1.25 and 8 inches long so I'm sure they stretch when torqued.
Old Feb 25, 2009 | 07:46 PM
HIGHOCTANE's Avatar
Yes I would..generally any bolt that is TQ to yield should be replaced..
Personally I always replace head bolts,main cap bolts and rod bolts..just to name a few..I also use ARP hardware when available. And I replace bolts with studs when available for the application..
