02 700 Twin
Old Feb 25, 2009 | 02:49 PM
farmer29's Avatar
Default 02 700 Twin
I was 20 min into a night ride when I noticed my temp gauge was flashing.The coolant
levels were perfect before ride and use polaris anti freeze.I stopped and noticed that the fan was not turning on but I could spin the fan by hand.I waited for machine to cool down and then topped up the rad with creek water and tried to ride it back home
with rad cap loose and I got about 200 yards and it started to heat up again but this time the fan had turned on when I stopped.I topped the rad back up for the second time and was able to ride out in low gear with rad cap loose. Any Idea's out there?
Old Feb 25, 2009 | 02:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default 02 700 Twin
why did you keep putting water into it? was it spitting antifreeze out from over heating? check the radiator (both sides,front and back) to see if its plugged at all.
Old Feb 25, 2009 | 03:11 PM
farmer29's Avatar
Default 02 700 Twin
Yes it was spitting antifreeze out
Old Feb 25, 2009 | 03:17 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default 02 700 Twin
well if you say your fan wasnt running then it could be a combo of the fan stoppedworking(just a small rock of twig can stop them) and maybe a partialy plugged radiator.if you put alot of watere in it make sure you get back the balance or least a 50/50 anti freeze water mix for correct cooling. hopefully it didnt get hot enough to take out the head gasket or warp the head. if you didnt drive very far w/ it overheated it shouldnt be an issue.
Old Feb 25, 2009 | 03:29 PM
farmer29's Avatar
Default 02 700 Twin
I stopped both times as soon as it started to overheat how can I tell if head gasket is no good or warped head because is ran fine and sounded normal on the way out?
Thanks for your imput
Sw00p
Sep 24, 2015 02:50 PM
greg74
Sep 10, 2015 07:58 AM
HondaR24
Jul 23, 2015 11:22 AM
Jul 7, 2015 11:00 PM
