04 650 v2
Old Feb 26, 2009 | 02:52 PM
hondafl350's Avatar
Default 04 650 v2
Hi I have a 04 650v2 and when I drive through snow the ATV starts shaking and if you look at the rear wheels it looks like one tire pushes then the other one pushes and they alternate from one to the other. What might be wrong with it?
(Ps) this ATV only has 900 km on it.
Thanks mike
Old Feb 28, 2009 | 07:30 PM
v2rider's Avatar
Default 04 650 v2
sounds like the rear diff is slipping, change the oil and see if it helps.
Old Mar 1, 2009 | 08:06 AM
hondafl350's Avatar
Default 04 650 v2
Thank you very much I will try that and see i it helps.
Thanks Mike
Old Mar 5, 2009 | 11:40 AM
flushot70's Avatar
Default 04 650 v2
ive read in these forums that the 04-05 v2s had frame issues. could you possible have a cracked or broke frame? i understand that they commonly break upper frame above wear your feet would go. maybe take the plastic off and take a look. good luck.
Old Mar 5, 2009 | 02:40 PM
hondafl350's Avatar
Default 04 650 v2
Oh, I hope not I just sold it the other day. Thank you very much
