How do I check the oil?
Old Feb 27, 2009 | 05:00 AM
floko35's Avatar
Default How do I check the oil?
Here is an easy one. I just purchased a 2000 Polaris Xplorer 400 4x4. This is my first ATV and I just started working on it. The electric indicator lights are out so the low oil light does not work. How do I manually check the oil? Also I know the chain is loose, how do I tighten it? Thanks all.....
Old Feb 27, 2009 | 07:16 AM
eggenz7's Avatar
the low oil light is for the two stroke oil in the front of the machine. in the hood piece is a cap. unscrew the cap and put your finger in there. if it comes out clean add more oil.
Old Feb 27, 2009 | 07:19 AM
Kerbbirds's Avatar
I believe thats a 2 stroke,right? There is an oil tank in the front if the machine you need to look in it to check the 2 cycle oil. Take the 2 bolts loose on the back of swing-arm and turn the eccentric forward with a large pair of channel-lock, that will do the chain.
Old Feb 27, 2009 | 07:48 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its a 2 stroke so its the oil inthe fron of the bike you need to add. it wouldnt hurt to check and maybe replace the counterbalancer oil as well.
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
