Kodiak 400 4X4 indicator light problem
Hello everyone new to the sight and need some help on a problem that I'm having. Thanks in advance for all the help.
I have a 2004 Yamaha Kodiak 400 4X4. Two of the four indicator lights are not working. I changed all the bulbs around and all the bulbs are good. I also checked all the fuses and they are all good too. The neutral light and 4X4 lights are not working. The 4X4 works though, but no light. Could a have a wiring problem? Can't seem to find the problem though. Are there any other fuses or something else to check out? I'm pulling my hair out! Hahaha.....
Thanks, Chris
Thanks, Chris
I'll look into that next. Maybe where the bulbs plug in the contacts are dirty? I'll clean them up better too. I'm not to good when it comes to electrical problems. Thanks, Chris
It could be there is a switch that is activated when in 4x4. Maybe something is a little out of adjustment and the switch is not getting turned on. See if you can trace the wire. Also you can look at the online parts diagrams to see what parts might need checking.
bzdok1234
30
Feb 23, 2016 01:55 PM
ranvette
Jul 4, 2015 06:13 PM
