Help, 91 trail boss 350L
Old Mar 3, 2009 | 12:56 PM
mikesgood4u's Avatar
Default Help, 91 trail boss 350L
I just replace the throttle/oiler cable, when I tried to start it it just turned over, now all the selonoid does is click when I try to start it. Batter is fully charged, I even tried jumping the selonoid and I get nothing... is there a fuse I don't know about??? Thanks
Old Mar 3, 2009 | 01:04 PM
MEGA XP's Avatar
Do you have any corrosion or is one of the terminal loose? Just a thought.
Old Mar 3, 2009 | 01:09 PM
I cleaned all the connections, the Haynes manuel keeps refering to a fuse/circuit breaker, but does not show a picture of it or it's location
Old Mar 3, 2009 | 09:32 PM
mkgearhead's Avatar
If you jumped the solenoid and still got nothing, it is probably the starter or the cable to the starter. There is no fuse between the solenoid and the starter.
Old Mar 3, 2009 | 10:00 PM
eggenz7's Avatar
what about battery voltage. is it charged all the way up?
Old Mar 3, 2009 | 11:55 PM
MEGA XP's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: eggenz7
what about battery voltage. is it charged all the way up?</end quote></div>
yeah, sometimes the battery can read a full charge but as soon as you load it nothing. Take the battery to advace and have it load tested. They do this for free.
Old Mar 4, 2009 | 02:55 AM
MrMarty51's Avatar
A fully charged battery should read about 12.5 volts on a volt meter.
As Mega XP suggested get it load tested than if the battery is OK start diagnosing from there.
You can not do a proper diagnostic procedure on any electrical component with a dead or bad battery.
Old Mar 4, 2009 | 04:18 AM
[img]i/expressions/face-icon-small-happy.gif[/img] Got it.... a few tapps on the starter and it cranks up, after the first time I no longer had to tap on the starter..... should I start looking for prices of starters???
Old Mar 4, 2009 | 04:23 AM
MrMarty51's Avatar
Maby try a disasemble on the starter to see if it has moisture,dirt or a buildup of carbon from worn brushes.
Also check the brushes and springs to make sure the brushes are seating on the commutator.
check for any loose connections.It might be a loose or corroded battery terminal connection at the starter.
Old Mar 4, 2009 | 09:31 AM
MEGA XP's Avatar
I agree with MrMarty51, and if you find wear you have 2 options. 1. order a new one $$$. 2. Take it to elec. motor shop see how much to re build it, this way you can get them to put some heavier components in so you don't have the prob again.
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
Brandon400
Sep 5, 2015 08:44 PM
JakeXBL
Sep 5, 2015 01:08 PM
Canamaniac!
Sep 4, 2015 06:44 PM
