600 Sportsman coolant leak
I recently did the stator/coil upgrade and noticed some anti freeze leaking from one of the threaded bolt holes that hold on the stator/flywheel cover. The bolt hole is located on the side of the water pump. Does anyone have any suggestions as to what may be causing the leak? It seems like an odd place to have coolant leaking from. Thank you.
It's definately not leaking from the weep hole. I am having a hard time figuring out how the coolant could leak out of the bolt hole that is near the stator. Is there any type of seal between the water pump and the stator housing that I should be looking for? The bolt hole is located at about 3 o'clock on the bolt hole pattern that the stator cover bolts onto. Any ideas? Thanks.
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
