400ex oil prob
Old Mar 8, 2009 | 12:51 PM
justjumpit's Avatar
Default 400ex oil prob
I have engine oil coming from the air box and seems to be coming up from the crank case vent. What is causing?
Old Mar 8, 2009 | 01:12 PM
Doctorturbo's Avatar
GOT BOOST!
Only two things I can think of: (if it's a wet sump; I think it is?)
#1 Excessive oil in the crank case. (level too high)
#2 Excessive crank case pressure caused from bad rings.
While running, if you have a hurricane coming out of the breather you can bet it's #2.
Old Mar 8, 2009 | 01:25 PM
justjumpit's Avatar
I appreciate the info. Its gotta be #2. Thanks again.
Old Mar 8, 2009 | 01:32 PM
GOT BOOST!
No problem.
You can check my diagnosis by doing a leakdown. This will tell you whether I'm correct or not.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
BigCam
Sep 16, 2015 01:53 AM
