Tapping noise on 2007 Foreman 500 4x4
Old Mar 9, 2009 | 12:35 AM
cjford717's Avatar
Default Tapping noise on 2007 Foreman 500 4x4
I have an 2007 Foreman 500 that i just put a crankshaft w/ rod in and all new bearings,piston,rings, gaskets. It has a light knocking sound coming from the lower portion of the engine. It will make the sound whether atv is moving or not. The last time i rebuilt it i put a new wristpin and piston and rings and it made the same sound. I took off the front cover to check the clutches, everything seemed to be ok. I need some opinions please help. thank you.
Old Mar 9, 2009 | 10:21 AM
cherokee99's Avatar
check out your cam, pushrods, rockerarms, and even valve clerances. i know you said it comes from the bottom of the engine, but in my experance a tapping sound in a pushrod engine is cam to valve problem.
Old Mar 9, 2009 | 12:03 PM
cjford717's Avatar
ok i will check that. Thank you.
Old Mar 10, 2009 | 05:59 AM
JeffinTD's Avatar
Also check or replace cam chain tensioner.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Sep 23, 2015 06:23 AM
