Loud clicking noise coming from back wheel area
Old Mar 9, 2009 | 11:22 PM
broski's Avatar
Default Loud clicking noise coming from back wheel area
i had another question about a problem i ran into and some useful information was posted so i figured i see if anyone could help me out with another problem im having. i have an 08 trailblazer 330 and when i get going around 10 mph and up i start to hear a clicking type noise. the noise is some what loud (loud enough for the people riding behind me and beside me can hear it aswell.) im almost positive the noise is coming from the rear of the atv. any help is appreciated. thanks
Old Mar 9, 2009 | 11:30 PM
broski's Avatar
just asked my brother how he would describe it and he said it was clacking type noise if thats helps. thanks (i know pretty much same thing but i thought i would throw it in their)
Old Mar 10, 2009 | 06:03 AM
shreker08's Avatar
Put it up on jack stand have someone run the throttle and listen for where the noise is coming from and get back to us
Old Mar 10, 2009 | 07:26 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is the chain loose or to tight? sometimes the chain will make that noise when its on the sprokets. check it for being loose,tight and maybe even worn out on the spokets. either way get it straighten out before you put too many more miles on and it does become a problem and cost you money to repair it. imo.
Old Mar 10, 2009 | 12:42 PM
broski's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: shreker08
Put it up on jack stand have someone run the throttle and listen for where the noise is coming from and get back to us</end quote></div>
good idea i will go do it this afternoon. thanks
Old Mar 10, 2009 | 12:44 PM
broski's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
is the chain loose or to tight? sometimes the chain will make that noise when its on the sprokets. check it for being loose,tight and maybe even worn out on the spokets. either way get it straighten out before you put too many more miles on and it does become a problem and cost you money to repair it. imo.</end quote></div>
that sounds like it could be the problem just by the way you describe it. i will go jack up my back end later and see if that may be the problem. thanks
Old Mar 10, 2009 | 12:45 PM
broski's Avatar
any other suggestions would be appreciated. thanks
Old Mar 10, 2009 | 01:02 PM
DELUX500EFI's Avatar
BUY AMERICAN!
same noise comes when you have a roller misssing or broken on the chain..The roller is the part the sprocket rides on..Have ran in to this very often..
Old Mar 10, 2009 | 01:31 PM
broski's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: DELUX500EFI
same noise comes when you have a roller misssing or broken on the chain..The roller is the part the sprocket rides on..Have ran in to this very often..</end quote></div>
how would i figure out if this was my problem. im going to jack it up in the back here shortly and see if i can figure out where the noise is coming from. any help is appreciated thanks
Old Mar 10, 2009 | 01:55 PM
BUY AMERICAN!
The way I check is jack the rear of atv up-put in neutral and turn wheel and look at the roller as it turns.sometimes it takes a while to spot bad roller..
