350x into my zuki
Old Feb 11, 2001 | 06:23 PM
QuadDude05's Avatar
i own AN LT 230 QS, and i have the quad tore down and ready for a total rebuild, i plan on putting a 350x motor in it, does anybody know if this motor is too big to be put in the fram or not? and suggestion or comments would be nice
Old Feb 11, 2001 | 10:17 PM
bermbanger's Avatar
Dude I've basically gave up on my 1986 230 quadsport. I'll tell you this......If you do get it in there its gonna give one hell of a ride! And i mean rough too!
Old Feb 14, 2001 | 10:42 PM
sombre's Avatar
I don't know about the 350X or the sport frame,but I put an XR350R motor(same bottom end as 350x but has a 4 valve head) in a quad racer frame.I had to lower the bottom frame rail about an inch. The sports are to short to start with so even if you get the motor in you are gonna need a longer swingarm.But it should be a good ride.
I'm just sorting out the jettin/timing on mine and it already runs awesome.Can't wait for some dry warm weather when it will hook up good.
Greg
Old Feb 15, 2001 | 11:00 AM
QuadDude05's Avatar
so i can put an xr350r motor in it?? where can i find a longer swingarm?? haven't seen any. and why would i need to make it longer?
Old Feb 15, 2001 | 06:20 PM
sombre's Avatar
{retty much any motor will fit any frame....with enough work that is. just for starters I'll say that neither the 350x or xr350r motor will likely fit in vertical height.I may be wrong because I have limited knowledge of the sports.So either the top backbone or the bottom rails of the frame are going to have to be moved...Not impossible but not an easy task either.
Second going from suzuki to honda chances that any of the motor mounts will line up are pretty remote.So you will have to fabricate ne mounts.(I think I spent more time on this than anything.).
Next is exhaust.No idea here I got lucky with the racer frame and the mods I did I used the dirtbike pipe with only a little bending.I think the 350x would be a little easier here cuz if memory serves me it only has 1 exhaust header.(xr350 has 2 just like the 400ex).
Now you gotta get it started...the XR and I thin the 350X both kick rearward not forward like your sport and the kicker needs to more a long way to start those big thumpers.even on the racer I had to more the pegs and redesign the rear brake.
next up is electronics....pretty easy here just need diagrams from the sport and what ever the donor motor came from so you can splice things together.
air filter anyone?????I just used a clamp on for the carb.But it limits the amount of water I can cross with the quad.
After all that you still have a quad that was to easy to wheelie to strt with and you added even more power....That's why you need the longer swingarm...any of the aftermarket companies should be able to make you one...For the right price...
My advice hop up the sport motor and look for either an LTR frame or a fourtrax 250r frame for your 350x project.
Greg
Old Feb 15, 2001 | 11:37 PM
350ex's Avatar
The 350x has dual pipes like the 400. Also the 230s kick starter kicks outward.
Old Feb 16, 2001 | 01:30 AM
Stroker's Avatar
I have seen that conversion done before. They use the stock swingarm becuase the Duadsports are used for rubber ice racing. I do not know any specifics, just that it's definitely possible.
Old Feb 16, 2001 | 10:45 PM
SandDraggin's Avatar
Just for those who don't know. A 350X engine IS a 4 valve engine like its sister the XR 350R and a 350X DOES kick foward. The xr engine kicks backwards.
The wire harness will have to be used of the 350X donor bike.
The header pipe on the 350X engine is a 2 into 1 pipe.
scottdubya83
Aug 29, 2015 04:08 PM
owen350x
Jul 30, 2000 01:58 AM
YellaTerra
Mar 30, 2000 04:38 PM
projectX
Mar 18, 2000 04:15 PM
