How to reset code
Old Mar 12, 2009 | 05:17 PM
asylum's Avatar
Default How to reset code
I did a search, but when I try to read the threads, it says abort. So I am posing the question here. I have a 2005 Sportsman 700 EFI and my wrench is flashing. I need to reset the maintenance code, but I don't know how. So how do I reset the code?
Old Mar 12, 2009 | 06:14 PM
DCT's Avatar
DCT
Banned
From the 2005 700 owners manual...
Diagnostic Mode
The diagnostic mode is for informational purposes only. Please return your ATV to your dealer for all major repairs.
As long as the gauge is in the diagnostic mode, the wrench icon will remain lit.
To leave the diagnostic mode, turn the key switch off and on.
NOTE: Any movement of the tires will also take the machine out ofthe diagnostic mode.
To enter the diagnostics mode:
1. Turn the key switch off and wait 10 seconds.
2. Set the park brake and shift the transmission to neutral.
3. Hold the mode/reverse override button and turn the key switch on.
4. Release the switch as soon as the display is activated.
The initial screen display refers to the software version installed in
your ATV. This information is displayed briefly.
Use the mode/reverse override button to toggle through the diagnostic
screens.
Screen 1: Battery voltage
Screen 2: Tachometer
Screen 3: AWD diagnostic
This gauge indicates whether or not current is flowing through the
AWD coil (only on models with switchable AWD).
Screen 4: Gear circuit diagnostic
This screen displays the resistance value (in ohms) being read at thegear switch input of the gauge.
46 FEATURES
Instrument Cluster
Rider Information Center
Diagnostic Mode
Screen 5: Programmable service interval
The purpose of the programmable service interval is to provide the consumer and dealer with a convenient reminder for routine maintenance. When your vehicle leaves the factory, this feature is set at 50 hours. You must enable the programmable service interval before it
can be used.
Once the service interval mode is set with the hours when service is due, the hours of actual engine operation are subtracted from the set
hours until 0 is reached. When the counter reaches 0, the wrench icon will flash quickly for 5 seconds each time the vehicle is started as a reminder that the periodic maintenance is due.
To set the hours, press and hold the mode/override button until the wrench icon flashes. When it begins to flash, release the button. The setting will increase by one hour each time the button is pressed.
Pressing and holding the button will allow the numbers to escalate much faster. When the desired time increment is displayed, release the button and wait for the wrench to stop flashing. When the wrench stops blinking, your service hours are set.
NOTE: If you scroll past the intended number, hold the button down until the count turns over to 0. You can then reset the number.
If the service interval is enabled on your ATV and you wish to turn it off, toggle to the service interval mode. Press and hold the mode button for approximately 7 seconds until the word OFF appears in the
Rider Information Center.
Old Mar 12, 2009 | 06:36 PM
asylum's Avatar
Thanks Dave!
Old Mar 13, 2009 | 06:03 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you cant get it better then that. good job DCT
Old Mar 13, 2009 | 09:15 AM
JCDEYO25's Avatar
I agree.....Nice job DCT.
John
Old Mar 13, 2009 | 06:03 PM
DCT's Avatar
DCT
Banned
No problem asylum... and thanks guys. However, I can't take much credit. I simply went to the Polaris site, logged in, found the manual and copied and pasted that page in here. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 14, 2009 | 03:44 PM
JCDEYO25's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: DCT
No problem asylum... and thanks guys. However, I can't take much credit. I simply went to the Polaris site, logged in, found the manual and copied and pasted that page in here. [img][/img]</end quote></div>
Ya big cheater.....lol....jk....
John
panicmanic
Sep 28, 2015 12:59 PM
Sw00p
Sep 24, 2015 02:50 PM
Alex G.
Sep 19, 2015 06:34 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
