yfz450 back fireing problems
Old Mar 13, 2009 | 11:50 AM
morton_35's Avatar
Default yfz450 back fireing problems
i got a yfz450 06 model and it does good goin up thro tha throtal but when u let out of it it starts to back fire purdy bad!! its got a full LRD PRO 4 R EXHAUST SYSTEM, GYTR CDI BOX AND AIR FILTER. AND A GYTR JET KIT. any body know wt cld be tha problem thanks.
Old Mar 13, 2009 | 12:09 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Wow dude. Not trying to be rude but that's hard to read.
Your lean on the idle. Screw in the idle screw all the way and back out 3 turns. Run and try again. If keeps doing it back out half a turn. Try again. If it keeps on try one more half turn. If it persists you'll should probably clean the carb a bit and make sure that idle jet is good and clean. You may have to go up a size on the pilot but, I wouldn't think so. Good luck with it.
MikeyBoyesq
Nov 27, 2020 02:44 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
Steven Bandemer
May 27, 2015 07:39 PM
