backfire 450 forman
Old Mar 14, 2009 | 12:50 AM
muddaddy1's Avatar
Default backfire 450 forman
98 450 es backfires when deaccelerating.how do you cure this problem.
Old Mar 14, 2009 | 02:41 AM
JeffinTD's Avatar
Likely running lean. Could be air leak in the intake manifold, or if you've changed muffler or whatever and didn't change jetting...
Otherwise, you might bump up idle mixture slightly.
My 500 will pop from time to time on a really steep downhill, but it has since new and it runs fine otherwise, so I'm not inclined to mess with it.
Old Mar 14, 2009 | 05:10 AM
muddaddy1's Avatar
Thanks for the info.that could be what it is.i turned the ide way down the other day.i'll boost it up again and try it.thanks again.
Old Mar 14, 2009 | 07:55 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Could be a gummed up idle (slow/pilot) jet, leaving you lean. As mentioned, an air intake leak somewhere is likely as well.
Old Mar 14, 2009 | 12:01 PM
Gimpster's Avatar
On the 450, if the air fuel mixture screw is not adjust out far enough, it will backfire. Turn the fuel air mixture screw out 1/2 turn ride checking for improvement.
A few other issues that will cause this is if a float valve needle is not seating completely. When decelerating the over abundance of fuel from a high fuel level in the bowl will not completely burn in the combustion chamber and the mixture will explode when exposed to hot exhaust system.
An air leak in the exhaust system will also cause backfiring under decel.
A tight exhaust valve or faulty decompressor on the camshaft will cause a backfire
A carb primer diapram with a hole in it will leak too much fuel into the carb and cause the backfire
Most likely the first mentioned air fuel screw adjustment is off. The 450 likes to breath with this screw set at around 3 turns from seated position. How yours is set, it may need to backed out 1/2 to 1 turn to cure the issue
Also make sure your spark plug is not carboned up. Too much soot build up will give the plug the wrong characteristics for it's heat range.
----- Gimpster -----
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
