2007 Honda trx 450er
Old Mar 14, 2009 | 08:35 PM
allenduren's Avatar
Default 2007 Honda trx 450er
ok i got asome ques on the started silinoid is it suppose to be puttin a full 12 volts to the start??????? the starter seems like it drags and it is only gettin 10 volts or so... and also why do these atv start so hard!!!???
Old Mar 15, 2009 | 12:21 PM
Ol Red's Avatar
Yes it should be putting full battery voltage to the starter. I would check the battery voltage, if you have battery voltage on one side of the solinoid and not the other side of the solinoid with the solinoid engaged the solinoid is bad. If you have same voltoge on both sides of the solinoid and not at the starter the cable from starter to solinoid may be bad.
Old Mar 16, 2009 | 05:37 AM
Stoopidbot's Avatar
It is not all the ERs that start like that. If you have a fully charged battery and your valves are in spec it will fire up easy.
http://s222.photobucket.com/al...w&current=DSCF3821.flv
Old Mar 19, 2009 | 09:22 PM
allenduren's Avatar
OK NEW PROBLEM!!!! starter still gettin the voltage.. turns over but the engine dont turn over!!!!! if put in gear and get motor to turn over little bit it will turn over and then stop and starter sounds like spinning but dies down what could itbe????????/
Old Mar 20, 2009 | 12:26 PM
Stoopidbot's Avatar
Does your battery have a full charge? A low battery may have enough juice to turn the starter but not the motor.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
ylomnstr
Sep 4, 2015 05:02 PM
Sjrpp
Jul 5, 2015 09:04 PM
