ES clutch issues?
Old Mar 16, 2009 | 07:55 PM
12guns's Avatar
Default ES clutch issues?
2006 Foreman 500 ES. If I'm coasting in any gear, I can't down shift. I have to give it a bit of gas then it will shift. When I pulled back into my garage, it almost didn't shift at all...I adjusted the clutch a couple weeks ago and haven't really ridden much since then, would you say I need to "increase" or "decrease". I know you're supposed to turn counter clockwise until resistance felt, then 1/4 turn back to the right. Thought I did that and maybe someone can help? thanks
Old Mar 18, 2009 | 07:41 PM
12guns's Avatar
Anybody?
What will happen as I "increase" and "decreae" the play in the clutch.
I rode again today, and w/ a cool engine it seems smooth as silk and will shift while coasting. After it warms up, seems to not be as smooth and sometimes I have to give it a bit of gas to shift down. Other times works fine.
Old Mar 18, 2009 | 08:20 PM
LOANSHARK's Avatar
Try adjusting it again... it takes a light touch. I find it easier to feel the slight resistance if I turn the shaft of the screwdriver rather than the handle. I usually have to go back and forth several times to feel when the reistance starts. Good luck, and come back to let us know what happens...
Old Mar 18, 2009 | 08:22 PM
LOANSHARK's Avatar
Oh, and don't forget to make sure that the locknot is backed out plenty before you adjust.
ghost civic
Jan 15, 2020 07:43 AM
Mikesohio
Jul 26, 2015 10:51 AM
ghost civic
Jul 15, 2015 10:48 PM
Unzzy66
Jul 11, 2015 10:01 PM
200es
Jul 10, 2015 09:09 AM
