No fire to plug on 99 Big Bear
Old Mar 19, 2009 | 09:17 AM
grego101's Avatar
Default No fire to plug on 99 Big Bear
My 1999 Big Bear will not start. It was running fine then the battery went dead. Bought a new battery. Turns over just fine but won't fire the plug. I could not find the problem so I took it to a mechanic. He said he checked the coil and everything else, and was 99% sure it was the CDI. I said are you sure, because the way it just quit firing the plug, it didn't sound like it was the CDI. He was wrong. I put a new one... $$$! Plus the cost of the mechanic! Still the same problem. Let me reemphasize something, it will turn over fine. Also I put a new starter solenoid on it because one of the wires fell off of it. I forgot too much about these things and need some help, haven't had one in years. Will probably have to trace the wires to the coil and figure out why it is not getting power.
Old Mar 19, 2009 | 09:45 AM
TLC's Avatar
TLC
I just changed the ignition coil on a Big Bear and it solved the same problem, quick cheap fix. Always start at the cheap stuff before moving to the more expensive stuff like Stators and CID boxes.
Old Mar 24, 2009 | 09:30 PM
grego101's Avatar
Changed the Ignition Coil. Still won't run. Turns over but no fire to plug. So far New CDI, Starter Solenoid and Ignition Coil. Are there any switches that let it turn over and not fire? I would think that any safety switches would not even let it turn over.
Old Mar 24, 2009 | 11:09 PM
HeftyLefty's Avatar
Did you change the plug?. They can fail too, you know. Check all kill switches, ignition and brake light switches, anything that can kill spark. How about stator keyway and stator ignition pulse pickup, do they check out OK?.
Old Apr 29, 2009 | 09:14 PM
cadillacdude1975's Avatar
check the kill switch.
Ean
Dec 19, 2022 08:48 AM
SDR-II
Sep 29, 2015 01:06 AM
Captjay
Jul 23, 2015 12:33 PM
chammerbeck
Jul 17, 2015 08:06 AM
clsharky
Jul 13, 2015 02:07 PM
