quick ?
Old Mar 19, 2009 | 09:38 PM
gsjeepxr's Avatar
Default quick ?
just put a slip-on; on with k&n and drilled lid. was running a 146(dont know why) jet before and just went to a 42/155 but dont seem to notice any difference. also at full speed and letting off the gas i get no popping but in 1st and 2nd i get just a very faint pop after full throttle. did the same thing before jetting. is this normal or should i try a bigger main. seems to pop more with the air screw in. its about 3 1/2 turns out. will check plug tomorrow biengs i put a new 1 in at the same time.
also how hard is it to change the cam chain. i have a knocking noise when its cold but goes away when it warms up. replaced exhaust gaskets and adjusted valves. will a cam chain give these signs?
thanks
andy
Old Mar 20, 2009 | 06:31 AM
gambler_m_99's Avatar
Default quick ?
The knocking noise you hear when you first start is nothing to worry about. That is just the nature of the beast (they all do it to some degree),
flyin-lowe
Dec 1, 2017 03:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
cornermike
Sep 10, 2015 08:30 AM
Rooky
Sep 9, 2015 03:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
