Weird Warrior Problems
Old Mar 20, 2009 | 04:32 PM
Yam_Blaster's Avatar
Default Weird Warrior Problems
the warrior has been having trouble starting, when i push the "start" button it gives off a "clicking" sound as if the battery is drained even though i charged it enough to start. so i tore the bike down and checked every loose wire and it started to work just fine. yesterday while we were riding, my brother hit this big jump on the warrior and when he landed, the bike shut down and it wouldn't turn on, then i found out the positive battery wire tore off from the landing so i brought it home and fixed it but when i tried to start it, the starting motor wont even spin at all, actually nothing happens AT ALL!! . any suggestions
Old Mar 20, 2009 | 11:22 PM
anyone??!!
Old Mar 20, 2009 | 11:29 PM
jaytau's Avatar
check your fuse that would be the first on my list after ripping the cable.
Old Mar 20, 2009 | 11:33 PM
it still looks good, i tore the thing down today and checked a few wires that i think might be the problem but when i try to start it, it wont even try to turn over, actually not even the headlights turn on
Old Mar 21, 2009 | 02:15 AM
JLsparky7's Avatar
Test the battery. Should be above 13 volts. Has to be a wiring problem, keep going through it.
Old Mar 21, 2009 | 10:35 AM
ill try charging it more today, but is there another thing that might also be the problem?
Old Mar 21, 2009 | 03:27 PM
JLsparky7's Avatar
CDI or fuse.
Old Mar 21, 2009 | 03:45 PM
i was reading in the service manual something about the bike recharging the battery by itself while its running...do you know if the CDI or some other part is involved in the recharging?
Old Mar 21, 2009 | 05:06 PM
91Warrior357's Avatar
the rectifier does the recharging, it looks like a little mini amp and has heat sinks on top of it, theres gotta be a bad ground or a wire that fell off or something, ive had this happen a few times myself.
Old Mar 21, 2009 | 05:33 PM
oh yea i know what you are talking about...hmm...ill see if the wires are messed up or missing
