need help with rear brake drum on a 97 honda recon
Old Mar 20, 2009 | 05:15 PM
Lil_Edd's Avatar
Default need help with rear brake drum on a 97 honda recon
the brake cam, that the brake arm is connected to does not want to rotate smoothly, its pretty much froze up. what do i have to do to remove it. thanks
Old Mar 21, 2009 | 02:57 AM
jhodge242004's Avatar
Remove all the the plate from the four-wheeler. Then remove all the hardware from the brake cam. BE VERY CAREFUL but you have to beat it out if it moves some it might not be bad. Mine was completely stuck and I got it out. Use a wire brush either on a drill or bench grinder clean the cam really well. Use sandpaper roll it up and clean the hole the cam slides through. Grease the eh out of it (lots of grease will keep it working smoothly for a long time). Re-assemble and ride!
Old Mar 21, 2009 | 10:49 PM
Lil_Edd's Avatar
thanks for the help, i pretty much wasted my time though. i figured it out about 15 min after i posted this thread, but now my breaks are really smooth. i guess i need to drain them after going through tire deep mudholes
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
rcappie4
Jul 10, 2015 04:54 PM
MNatv89
Jul 7, 2015 11:36 AM
Rider252
Jul 6, 2015 03:37 PM
