300EX bearing carrier replacement
Old Mar 26, 2009 | 03:37 PM
outside2day's Avatar
Default 300EX bearing carrier replacement
Am going to need to replace this I think after breaking some of adjuster ears off and exposing edge of seal. Recomendations good or bad? ebay has some aftermarket ones around $100-120 various brands?? thanks
Old Mar 26, 2009 | 04:18 PM
TractorPacker's Avatar
Do you have a balloon?
Get an aftermarket one, that has the grease zirk on the outer edge. Being able to grease those bearing while assembled is really nice. A new stocker will cost over 200 bucks and it will break.
Old Mar 27, 2009 | 03:59 PM
thanks Tractor, saw those with outside zerks and like that. anyone else? good or bad experience with brands? Stay away from?
Old Mar 27, 2009 | 10:31 PM
Tim Smith's Avatar
Glad I was wrong about the dealer only part. I like the grease zerk idea. Grease is ALWAYS better than no grease.
Old Mar 28, 2009 | 10:57 AM
Y2daT's Avatar
I bought one of the lonestar carriers with the double row berrings works great.....
.(note: inorder for the grease fitting to do any good ther caint be a inner berring seal.......check this before installing the carrier if the berrings are sealed on both sides juist pop out the inner seal ....then when you pak it full of greese the grease will actualy lube the berrings)
I learned this trick reparing lawn mowers ...the spindles that the blades ride on have sealed berrings so the greese fittings are useless unless you do the same trick..
juist another way for the companys to suck our wallets dry
Ean
Dec 19, 2022 08:48 AM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
joeyupton
Jul 14, 2015 11:51 AM
clsharky
Jul 13, 2015 02:07 PM
