No spark 250 polaris
I have a 250 polaris xplorer 4x4 with no spark issue. Can anyone tell me how to check stator coil in detail? Ive also herad there is a black wire on the cdi that could be shorted can anyone tell me more info on this?
Thanks
Thanks
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Resident Killer!
make sure that the spark plug wire is fully inserted into the spark plug boot. also you can unscrew the boot from the wire and snip about a 1/4" off the end of the spark plug wire to expose fresh new wire. Then screw the boot back into the wire.
Sometimes corrosion forms at this area creating a weak or no spark.
Also check the other end of the wire too. if this fails to produce spark then proceed with further inspection..............................coil?..... ...........stator?
go to your "user control panel" and then go to "edit avatar" then download a pic you want to display with your sign in name. Then it will show everytime you post on a thread on atvconnection.com
