polaris stuck in high gear
Old Apr 1, 2009 | 03:50 PM
cdogkiller's Avatar
Default polaris stuck in high gear
i got a polaris 325 i think its a 2000 or 2001 the dang thang is stuck in high gear. it was working fine earlier that day my daughter was riding it and she said it was getting were it wouldnt go and i got on it and it would go but it want drop into the low gear its stuck in high. does anyone have any ideas wat i can do to fix it besides getting a new clutch. thanks
Old Apr 1, 2009 | 05:04 PM
ftwflh's Avatar
Take the shift linkages off and try shifting with pliers.If this works it is in the shifter.
Not sure on what shifter is used on the 325 Magnums.But the older ones had a shifter that had oil in it and was prone to sticking up.
Old Apr 1, 2009 | 06:29 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is it stuck only when its running or when its off as well? if so try messing w/ the linkage as he mentioned.
Old Apr 6, 2009 | 11:23 PM
cdogkiller's Avatar
Default 325 magnum polaris stuck in high gear
yes my polaris 325 magnum 4x4 is stuck in high gear it will take off and go but i dont want to burn the belt up so if anyone has any suggestions to help me solve this problem i would be grateful thanks.
Old Apr 7, 2009 | 12:29 AM
BillR's Avatar
If you jack the rear end up. Do the tires turn without giving any throttle. Or is the gear lever stuck and you want low range for pulling ect
Old Apr 7, 2009 | 06:35 AM
Kerbbirds's Avatar
Unhook the linage at the tranny and see if it will shift, this will tell you if its in the shifter or the tranny.
Old Apr 7, 2009 | 06:40 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i take it its stuck even w/ the engine off? try kerbbirds sugestion to rule things out.
Old Apr 15, 2009 | 09:48 AM
cdogkiller's Avatar
tks for getting back with me, my quad is an automatic, i can jump on it right now and it will take off but if i load it up or get stuck it want drop into low gear to have that pulling power, it has the high end power but not the low end. just really dont know wat to do.
Old Apr 15, 2009 | 09:50 AM
cdogkiller's Avatar
this quad is an automatic its like it has no pulling power if i get in a bind. i can jump on it now and it will go i can ride in high gear but not low gear
Old Apr 15, 2009 | 10:04 AM
scootergptx's Avatar
Supersock
Hired Gun!
I have merged your two different threads into one. If someone notices a post they made didn't make it over, just send me a PM and I'll get that taken care.
Please note that multiple posting of the same topic is against forum rules.
txkevin
Sep 21, 2015 02:02 PM
Trade3
Ask the Editor
Jun 21, 2015 10:30 PM
Jun 10, 2015 11:20 PM
Big600twin
Jun 10, 2015 03:01 PM
Fullblast
May 26, 2015 12:38 AM
