Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
250 mojave problem need help
Old Apr 2, 2009 | 07:58 PM
mojavebigAir's Avatar
Unhappy 250 mojave problem need help
ok i lost half my speed and half power, i used to go 70 now i go maybe 30 and up hills,it barely makes it, also when id hit big jumps it would blow out a huge cloud of smoke often at times. i took it in to the shop and they told me i ran it low on oil, but didnt tell me what was wrong. can anyone help me and tell me what you think is wrong before i tear down the motor,its also a 2001 ive checked all the easy stuff and piston and rings looked fine
Old Sep 6, 2009 | 12:13 PM
honkaw's Avatar
Well I'm sure you have it fixed by now but you will have to do a commpression check to know whats going on. Sounds like the compression is low should be at least 70psi to run.
Old Sep 27, 2009 | 01:19 PM
Beastly 3hundo's Avatar
It may be a carb problem, but if it isnt I recomend a top end rebuild, piston, rings, and valves and valve seats. How long has it been since you got it rebuilt? They say a 4 stroke should get a top end check/rebuild (if it needs it) every 40-50 hrs of riding time. From experience, I learnd the hard way that a Mojave will run with bad valves all the way till thay come through the head .
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
