Rear cv boots????
Old Apr 4, 2009 | 10:35 PM
fishing28's Avatar
Default Rear cv boots????
back to CV boots went today while riding. both at same time. Have not ridden hard in a while guess they dry rotted and but hard miles on today. also went threw a little water on the way back to truck. How much am i looking at spending on getting this fixed?
Old Apr 4, 2009 | 11:39 PM
chuck_raduenz's Avatar
doing it your self $40 per boot pluse if its your first time a few hrs. bring it to a dealer id say total cost $300 per side replacing one boot. or so if they dry rotted id say replace all 4.
Old Apr 5, 2009 | 07:05 AM
mud moose's Avatar
you can get the boots with grease and clamps for 19.00 bucks a piece at www.mfgsupply.com .. make sure joints are clean and all ball bearings are there and cage are not damaged from mud grind..pretty easy to do good luck
Old Apr 5, 2009 | 07:13 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you rode it at all in the mud/water, you will need to clean them 100 % out and regrease to make sure they will last and make sur you put the clamps on right and tight to prevent any thing from getting into there and causing damage later on. imo.
Old Apr 5, 2009 | 09:47 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Make damned sure you buy the factory cv boots. They fit better and the clamps are better than the aftermarket boot kits.
Old Apr 5, 2009 | 11:40 AM
i agree. i got aftemarket ones. and the grease kept ozzing out. they seemed to hold up better. but they didnt seal real well.
Old Apr 5, 2009 | 12:13 PM
TLC's Avatar
TLC
I spray a rubber protection spray like this http://www.autogeek.net/four-star-ul...ant-spray.html on my boots every so ofter. It says
"Four Star Ultimate Tire Protectant Spray helps keep the rubber soft and pliable while preventing dry rot, cracking, and brittleness. The high bonding Polycharger polymers give the protectant excellent staying power through rain and daily driving. Your tires will look dark and supple with an attractive satin glow."
I,m hoping it helps CV boots also,and it only takes seconds to apply. I do see the water beading on the CV boots for sure after riding ,I guess thats a good sign. Great for those long winter storage times.
Old Apr 6, 2009 | 07:51 PM
fishing28's Avatar
Red face another quick question.
I am no professional mechanic but I have had my share of toys and have turned a few wrenches in the past. no motor work really but basics. is it that hard to clean, grease, and replace the cv boots? any special tools??? I just bought this 700twin a month ago, have ridden it 3 times, first time was good, second time it got stuck in 4wd, now the boots. and the speedo went out along with the milage. hopefully thats just a sensor though.. Thanks for all your help!!!
Old Apr 6, 2009 | 09:50 PM
switzomatic's Avatar
Default Boots
Spend the extra $ on the Polaris boots. If you have a manual you should be able to tackle the problem yourself. Make sure while you have everything apart to check hub bearings and replace if needed. I get mine off eBay and pay less for a pair than Polaris charges for one side. Also, when putting the axles back into the rear diff put some never seize on the splines first so they will be easier to get out the next time they need to be removed.
Old Apr 8, 2009 | 03:01 PM
Big600twin's Avatar
I bought the boots from mfgsupply.com and have not had any problems. It comes with a banding kit that so far has worked great for me and I see a lot of water and mud.
mywifesquad
8
Sep 21, 2015 08:20 AM
Tim Shoe
Sep 7, 2015 12:15 PM
DM2015
Sep 7, 2015 10:36 AM
black_thunder
Sep 7, 2015 01:24 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
