03 sp500 HO HUB STRUT SEAL O.E.M=1 KIT COMES W/2
I am relacing the bearing & seals on front drive and I am stuck at this point cuz the strut hub replacement bearing & seal kit comes with 2 seal (1 kit per axle) and the strut housing only had 1 seal (in the back) . The only thing I can thick of is that I should double up or stack both seals. The original seal was definitely thicker & the seat appears to accomadate both the new seals since they are alot slimmer.
Am I right or drinking & doing something that requires thinking or common sense doesn't mix?
Any body?
Any body?
exmotocrosser
Sep 13, 2019 06:12 AM
