Sluggish start on Sportsman
Old Apr 5, 2009 | 09:08 AM
Tpr430's Avatar
Default Sluggish start on Sportsman
I've got an 05 Sportsman 600 and its always been a sluggish starter. Everybody tells me Polaris are cold blooded. But even when its warm it always takes a least a few turns of the key to start. How can this be improved? What things can I do? Any help would be appreciated!
Old Apr 5, 2009 | 03:15 PM
JDSpud's Avatar
Have you replaced fuel filter, spark plugs, air filter, cleaned carb, used seafoam. does your fuel sit around alot, could be timing but not sure, good battery clean cables and ground. I'm not a great mechanic but if it where me this is what i would try this first
Old Apr 5, 2009 | 03:17 PM
JDSpud's Avatar
oh and i've got the exact same bike as you, mine starts just as fast or faster than all my friends efi's.
Old Apr 5, 2009 | 04:50 PM
700 sportsman's Avatar
I agree check all of the above things
Old Apr 5, 2009 | 05:12 PM
DCT's Avatar
DCT
Banned
Agreed with the others...
Change the air filter.
Clean or change the pre-filter on the air filter.
Change the fuel filter.
Use a good fuel system cleaner/additive.
Change the plug... try the NGK Iridium plug for your machine.
Old Apr 6, 2009 | 05:22 AM
Tpr430's Avatar
Seafoam, no. What is that? No to the fuel filter (have to find it), will be replacing air filter today, and not sure how to clean the carb, and just changed the spark plugs. I'd love to know where the fuel filter is. Thanks for the advice!!
Old Apr 6, 2009 | 09:30 AM
TLC's Avatar
TLC
Here instuction on cleaning a carb http://www.ripperd.com/ftp/admins/carb_rebuild/
Its a round slide not a CV but the choke pludger and bottom bowl/jets are the same procedure.
I,m on a sled forum were they will not even answer a question about hard starts until the carbs cleaned first.
Old Apr 6, 2009 | 04:35 PM
JDSpud's Avatar
the fuel filter is just above and to the right of your left front tire. it is a little white plastic tube clamped between the fuel lines. it only costs about 3$ if i remember right. if this is not real clear pm me and i will get you a pic.
Old Apr 6, 2009 | 05:59 PM
DCT's Avatar
DCT
Banned
I'm sure by now you've "Googled" the Seafoam and know what it is. Use it, or find something a little milder that you can use in every tank full of gas. The gas nowadays is pretty much crap, and that little rinky-dink fuel filter (if it's like mine) is going to be much help.
My advise is to learn how to maintain everything on your quad that you can. It will pay dividends down the road.
Old Apr 6, 2009 | 06:37 PM
JDSpud's Avatar
