1985 250r
Old Apr 12, 2009 | 10:44 PM
YARYAN's Avatar
Exclamation 1985 250r
hi i just bought a 1985 250r. best bike ive ridin. loads of power. but. my forks are really soft my cousin said i can add a lil air to the forks and theyll be stiffer. is this true?? also if it sits for like 5 mins gas starts pouring out the over flow! so i have to pinch the line but it doesnt do this when running. so any help with my problems will be greatly appricaited. thanks.
Old Apr 13, 2009 | 08:29 AM
sdm111's Avatar
2 strokes or 4
As far as the forks unless they have been rebuilt if you add any air you will probably mess up the seals if they will hold any air anyway, all the people that I know including myself just use the stems to relieve any air the shocks may have built up while riding. And the overflow problem is either a stuck float, the float needs to be adjusted, dirty bowl, or bad needle valve.
Old Apr 14, 2009 | 11:40 PM
YARYAN's Avatar
Thanks for the help. i didnt think adding air would do anything i just wasnt sure. how would i get the float to un stick? ive cleaned the carb like three times plus jetted it down. thanks again
Old Apr 15, 2009 | 08:13 AM
sdm111's Avatar
2 strokes or 4
Take the bowl off flip the carb upside down and fill the top of the bottom of the carb with water if it comes out where the fuel line goes to the carb the needle valve is bad. Also put the float in a glass of water just to make sure it dosen't sink from a small crack in it. If it's clean inside the bowl then the float isn't stuck. By the way, why did you jet it down may be leaning it out? not because of the carb issues?
Old Apr 17, 2009 | 12:35 AM
YARYAN's Avatar
because i bought it from a guy whop was ridin it at the coast. hince sea level i live in burns oregon which is like 5000 ft. so it was getting to much gas when i got into it. now that i jettedf it down it runs much better. thanks for all the help. do u no of a site with aftermarket parts? like foot pegs? pipes? thanks aghain
Old Apr 17, 2009 | 11:37 AM
sdm111's Avatar
2 strokes or 4
Oh I see, about the pipes duncan racing has some nice Paul Turner pipes, CT racing also, don't know about pegs and stuff usually for that type of stuff I surf e-bay you can find new stuff at good prices, enjoy your R.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
CRamshaw777
Jul 18, 2015 05:46 PM
