Starter, starter drive or battery?
Old Apr 15, 2009 | 01:47 PM
The original Firehawk's Avatar
Question Starter, starter drive or battery?
Hi guys.
Been a while since I posted in here, I guess I've been busy riding!
I'm experiencing some issues in starting the 2002 Polaris Sportsman 700 twin I own and would like to troubleshoot the problem.
Here's the symptoms.
With the battery fully charged, the starter turns the engine over slowly but it does start. Sometimes the starter makes a whizzing noise without turning the engine over and when I retry, the starter engages and successfully turns the engine over. It sounds to me like the starter is laboring and doesn't spin freely like the other quads... (Just an observation)
I believe the battery is good, but not sure about the starter motor or starter drive. Is there a way to trouble shoot the problem before purchasing un-needed expensive parts?
Thanks for your input guys!
Gary
Old Apr 15, 2009 | 02:44 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
well pull starting is out of the qestion for sure lol. if your 100% sure the batteries at full charge when your turning it over and its laboring, sounds like the starter might be dragging somewhat. might need a rebuild on the starter. imo
Old Apr 15, 2009 | 02:49 PM
Does Polaris sell these kits for the starter?
Old Apr 15, 2009 | 08:27 PM
Brush kits are available to rebuild starters,plus also I would check condition of starter bendix,could be dragging starter down Good luck
Old Apr 16, 2009 | 07:32 AM
Kerbbirds's Avatar
Be absolutely sure the battery is 100% mine acted simular , thought the battery was ok, finally battrey quit, put in a new dry cell, starts better than it ever did, the dry cell has more cold crankin amps and the starter hasnt missed a beat, can you load test the battery at your auto store?
Old Apr 16, 2009 | 03:27 PM
What do I look for when I look at the bendix?
Old Apr 16, 2009 | 03:34 PM
The battery is kept on a BatteryMinder Plus charger (de-sulphating). The battery, a polaris one reads 13.24 volts 5 minutes after charger has been disconnected
Old Apr 16, 2009 | 03:37 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would just get the starter rebuild as sounds like the battery is strong. imo
Old Apr 20, 2009 | 03:55 PM
Thanks guys, I'm putting that rebuild on my to do list.
BTW: Has anyone in here purchased a starter off of Ebay? I see them listed in there but wasn't sure what the quality would be...
Old Apr 20, 2009 | 09:46 PM
BARKERR's Avatar
Exclamation Starter
Had simialer prob with my 500. started out starting really slow(BATTERY FULLY CHARGED),then about a week later starter would just whine real fast.pulled starter out and put power to it sounded normal.Decided to pull drive out,yep it was frozen soild replaced it.All works good, now i have a problem with my solienod! hope this helps.
