2008 trailblazer thinks its hot
Old Apr 21, 2009 | 09:07 PM
azhuskyowner's Avatar
Default 2008 trailblazer thinks its hot
I have an 08 trailblazer that thinks its hot and has the temp light on. My fan is running before I even start it. when I attempt to start the ignition clicks and the fan starts running. if I pull start it will start just fine but the fan is running and the temp light is on. my guess would be the temperature sensor but not sure where that sensor would be located.
Old Apr 21, 2009 | 09:25 PM
TLC's Avatar
TLC
The pic is for a 330 trail boss but the motors the same. Its part #12 that tells the fan to come on or off and temp light I believe. They call it a "thermister". OEM motorcycle and ATV parts from Honda, Yamaha & Polaris – Cycle Parts Warehouse
Old Apr 22, 2009 | 05:32 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
should be 2 wires hooked to it. if someone has a manual or ask a dealer what t he test specs are on it w/ an ohm meter to see if its good.
Old Dec 4, 2009 | 03:32 PM
for anyone who reads this thread who has the same issue I learned its not the thermister, it's the power module this is just under the headlight. It's silver in color and it control anything that involves the ignition or power supply. Don't change the thermister if you turn the key off and the fan is still running. that would be the power module.
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
RedRancher
Jul 10, 2015 06:36 PM
traumajunkie
Jul 5, 2015 03:03 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
