xplorer 400l throttle cable
Old Apr 22, 2009 | 12:38 PM
eye1optical's Avatar
Default xplorer 400l throttle cable
In the process of replacing thottle cable for 96 xplorer 400l. Everything hooked up except for 2nd cable which goes to (i assume an oil injector front of motor). How does it attach to the lever in the oil injector and does anyone have a skematic of the oil injector before i dismantle.
Old Apr 22, 2009 | 04:43 PM
Screw the adapter and cable into the oil pump housing,turn oil pump wheel towards you and slip in cable through slot in wheel,slowly let wheel turn back with cable wrapped around it. Also turn cable adjuster to where line on wheel lines up with mark on pump body and tighten adjuster locknut.
Old Apr 23, 2009 | 02:54 PM
Thanks will take cover off and see what we have. Again thanks alot.
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
firsttimerider
Technical and How-To Articles
Sep 7, 2015 11:43 AM
sleepyva
Sep 2, 2015 06:32 PM
mrmickman123
Aug 30, 2015 10:37 PM
