Best 4by4
Old Dec 11, 1999 | 01:33 PM
clindst's Avatar
I would like to know what all u tink about the 4by4's out which is the best that can pull a lot and i dont really envy the 3WD limited slip's, also i need something that is around 400 to 500 cc, what do u think is the best gound clearence i also ride through deep water
Chris
Old Dec 11, 1999 | 04:59 PM
bignasty's Avatar
Uh oooooooh, I read water. Where ever there is water there is Max not too far away.
Old Dec 11, 1999 | 05:55 PM
Max6x6's Avatar
Max is the best ATV for all the stuff you listed. There is no comparison for water use. It will out pull any quad out there and is available from 480cc up to 725cc.
MaxRules
Old Dec 11, 1999 | 07:23 PM
TxDoc2's Avatar
Except for the 400-500cc requirement, I would have suggested a Hummer or Abrams M1A2(19" of ground clearance) And since you specified 4x4, you don't want a max, I guess, it is a 6x6.
[This message has been edited by TxDoc2 (edited 12-11-1999).]
Old Dec 11, 1999 | 08:07 PM
clindst's Avatar
Thanks for your replies but i am lloknig only at a ATV not MAX's Hummers or 6by6
Can u help
Old Dec 11, 1999 | 09:10 PM
Andy Bassham's Avatar
If you don't want a limited slip, then you are left with the Polaris models. 400 explorer, 425 Expedition, 500 Magnum and Sportsman. I'm not about to say anything about a Scrambler on the Utility ATVs forum.
Andy Bassham *(1999 Arctic Cat 500 4x4, 1989 Honda 300)*
Old Dec 11, 1999 | 09:43 PM
BONER's Avatar
I think the Sportsman 500 would be best because the snorkels are VERY HIGH and it has the highest ground clearance of the industry.
Old Dec 12, 1999 | 12:02 AM
clindst's Avatar
Boner the snorkels on the Magnum are jsut as high and also the Amgnum has the same ground clearance, auctually ihgher because when there is weight on the IRS it does "Squat" or lower, sooo i think the magnum is better but i am soo sorried about the Belt because i pull 6000 lbs and the tires take a while to break loose and am wondering if all that strain adn stress isn getting put on the belt? if so im screwed, ill be getting 20 belts a year HAHA
Chris, also what do u tihnk about the new rubicon, because it only engages into 4WD when the rear slips and if i put a locker in it it will be great its auto adn no belt? but im not sure it will have the sportyness of the Magnum, can ya help?
Chris
Old Dec 12, 1999 | 01:12 AM
Even with a little suspension squatting, the Sportsman still has more ground clearance than the Mag. We are of course talking of the rear gear housing of the Magnum being the lowest point on the quad (6-7 inches). You can't exactly count ground clearance as frame to ground on a straight axle quad, because when straddling something, the rear end will eventually hit. You would have to have some serious weight on the sportsman to squat it down to the magnum's low point. If the belt slippage is a factor and so is 4wheels pulling, then the Expedition 425 is the narrowing point.
Old Dec 12, 1999 | 03:25 AM
BONER's Avatar
No the Sportsman's Snorkels are higher than all the other Polarises.
