250x rad carrier
Old Feb 15, 2001 | 01:59 AM
rider820's Avatar
Is an aftermarket rad carrier hard to swap with my stock carrier? Should a rad carrier have a chain tensioner on it? And also do i have to do any mods at all to put the rad in my 250x? thanks..
Jeff
Old Feb 15, 2001 | 10:36 AM
DSAPP's Avatar
I'm confused...
help anyone???
Old Feb 15, 2001 | 11:12 AM
rider820's Avatar
Im just tryin to figure out what i have to replace to put a rad carrier in. Like, does a rad carrier come with a chain tensioner, and do i have to use the original brake caliper mount.
Jeff
87' 250x, mods in the process.
Old Feb 15, 2001 | 11:16 AM
Stroker's Avatar
The RAD Bearing Carrier is similar with other aftermarket bearing carriers on the market.As far as chain tension adjustability it will probably have more than stock. It will slide right in the housing with no mods and use the old brake caliper mounting plate. I have switched my stock carrier to a Lonestar unit and ran into no problems during the switch.
Old Feb 16, 2001 | 12:09 AM
54warrior's Avatar
Nicely put Stroker!!!
Old Feb 16, 2001 | 02:19 AM
rider820's Avatar
thanks for the help stroker!!
3quadbob
Sep 18, 2016 09:46 PM
Dammar
Aug 26, 2015 07:12 PM
big_g_squared
Jun 28, 2015 04:17 PM
Nut
Jan 1, 2001 06:13 PM
250rCanCan
Sep 26, 1999 01:51 PM
