Tiny Tach for Recon
Old Feb 15, 2001 | 11:56 AM
paulgp602's Avatar
I need to know which Tiny Tach to buy,the one that is for engines that fire EVERY crankshaft revolution or EVERY OTHER crankshaft revolution.Also does anyone know of a website that sells them?Thanks
Old Feb 15, 2001 | 12:00 PM
snowshark's Avatar
Check out Cabelas they have them. www.cabelas.com.
Not sure if Rockymountain ATV has them or not.
Old Feb 15, 2001 | 12:45 PM
Kman's Avatar
For 4 stroke the engine fires every other revolution, for 2 stroke it fires every revolution.
Kman
Old Feb 15, 2001 | 01:24 PM
Diogenes's Avatar
Not exactly, Kman; most small 4-stroke engines today have a "wasted" spark pulse at the end of the exhaust stroke (as well as the "real" spark pulse at the end of the compression stroke); the pickup triggering the spark discharge senses EVERY revolution of the engine.
Generally, old-style four-stroke point-and-capacitor ignitions fire every other revolution as you say.
Diogenes
Old Feb 15, 2001 | 01:41 PM
paulgp602's Avatar
So does that mean that the Recon uses the Wasted spark method?
Old Feb 15, 2001 | 01:44 PM
paulgp602's Avatar
Is that one on Cabelas the one that is for the fire every stroke or every other stroke 4 stroke..........Thats alot of strokes.lol
Old Feb 15, 2001 | 02:37 PM
Diogenes's Avatar
If you DO have a pickup coil sensing a lump on the rotor triggering a CDI; and, if you DO NOT have a points-and-capacitor ignition system; chances are, your plug fires EVERY revolution.
Diogoenes
Old Feb 15, 2001 | 02:38 PM
Kman's Avatar
Diogenes,
Thanks for the correction, you learn something new every day.
Kman
Old Feb 15, 2001 | 03:21 PM
Diogenes's Avatar
Thank you, Kman, for accepting the information in the helpful spirit offered.
You are quite right in the concept a four-stroke engine REQUIRES only one spark every two revolutions; however, for simplicity of manufacture, the "extra" spark pulse appears with pickup-coil triggered CDI systems. Some say the extra spark pulse helps environmentally, controlling emissions by incinerating unburned gasses. Maybe so; however, I bet that effect is very minor.
Diogenes
Old Feb 15, 2001 | 04:25 PM
Phil350's Avatar
So, with all that being said, we need the Tiny Tach that measures for fire every revolution, right?
