700 wont start someimes
Old Apr 29, 2009 | 09:04 PM
mudslinginfool's Avatar
Does it in the Mud!
Default 700 wont start someimes
my 2008 700 will crank over but wont fire up,untill you give it a little gas then it starts up. this is not all the time though. Yes,its under warranty i just wanted some opinions of what you all might think it is before i take it in. 250 miles on it. my guess is ecm or fuel pump? Obviously i shouldnt have to give it any gas since its efi. thanks.
Old Apr 30, 2009 | 07:18 PM
swampyjunior's Avatar
You might try replacing the spark plugs or cleaning the one that there. Also, does it have a choke? I am assuming if it does its electroninc? it might not be working. Clean air filter too to tule that out.Then, since it is computerized. Take it in and have them look at the ECU module for error codes.SJ
Old May 1, 2009 | 01:08 PM
Does it in the Mud!
Yeah the first time it did it it had about 150 miles on it with original spark plug, so i replaced it. it did it again though, air filter is clean(im a clean freak when it comes to my vehicles). Its electonic fuel injected so choke is electric. my other possible fix is my new ECU from VDI(copperhead). This may cure my problem. Thanks for the respond.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
