no pullers will work help
Old May 2, 2009 | 03:52 PM
200m's Avatar
Question no pullers will work help
need to get to the flywheel and cant get the magneto off tried pullers bolts took it to honda dont know why you guys think i could retap it and use a common thread n bolt? any help would be great! ITS A 1985 200M
Old May 4, 2009 | 08:49 PM
MadMel777's Avatar
you tried the puller from honda ?? the one that threads into the mag and pushes on the crank end
Old May 8, 2009 | 10:21 PM
200sATC's Avatar
Default Ive been here before
Put a few drops of oil down the center of the fly wheel..let it soak in there for about an hour or two...got a propane torch..get one..dont use an oxy acetylene unless you have experience..just cook that baby up a little in the center...dont cherry it just heat it to where its smoldering like a son of a be from the oil you soaked in to it..remeber thats a hardened shaft and if you get it to hot you will change the mollecular structure of the steel..tap it a few times with a hammer, dont smash it just tap it ..let it cool fore a few minutes and set up your puller and start pulling..while pulling tap the flywheel once or twice with a hammer just enough to shock it..between the expansion and contraction of the metal from heating and cooling and the ocassional tap it will let loose, if it doesnt work the first time repeat the steps thats all, be patient, that flywheel has been on there how many years, think about it, all that rust and crud that built up inside kind of welded itself together as one..the only thing i can say is dont give up.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
