Alternator bolt on brute force?
Old May 2, 2009 | 06:37 PM
miiller's Avatar
Default Alternator bolt on brute force?
Ok guys I have the manual for my 750 and Im rebuilding the top part of the engine and Im at the point now where i need to time it. It tells me this:
Using a wrench on the alternator bolt, turn the crankshaft
clockwise until “T-R” mark [A] is aligned with the notch
[b] in the inspection window.
Where is this alternator bolt at and where is the inspection window?
Thanks
Old May 2, 2009 | 08:47 PM
wowkoolaid's Avatar
take the pull start off and the nut is there. the inspection hole is on the right side of motor it it a round plug with a allen head
Old May 2, 2009 | 09:20 PM
miiller's Avatar
Ok you say the right side of the engine, do I have to take the belt cover off and its behind there? Thanks for the reply man...this helps alot.
Old May 2, 2009 | 09:33 PM
wowkoolaid's Avatar
my bad it is on the left side just up and back from the pull starter
Old May 2, 2009 | 09:49 PM
miiller's Avatar
Ok thanks. You wouldnt happen to know the answer to my other thread would you? How can I tell where top dead center is at the end of the compression stroke?
Old May 3, 2009 | 02:34 PM
wowkoolaid's Avatar
if u send me ur email i will try to send the pages on how to tome the cams to u . i have the manual loaded on my computer
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
