bad rear wheel bearing on 02 scrambler
Old May 2, 2009 | 08:33 PM
opcruzer's Avatar
Default bad rear wheel bearing on 02 scrambler
I am trying to replace the rear wheel bearings on my 02 scrambler 4x4. I have the axle assembly out of the the swing arm and in the vise and I can not get the nut off either side of the hub assembly. I have tried about everything and neither side will give. We tried some heat with a torch and it moved a little but not much. What is the trick to getting the the threaded nut/hub off one or both sides. I have done this job on older honda three wheelers so I am familiar with the general idea but this one has us stumped.
And one little bit of advise, the bearing and race assembly was $13.xx at my local sturdevants auto parts store and the local stealership charged me almost $19 for just the bearing. The brand of bearing and the numbers matched exactly.
Thanks for the help.
Old May 2, 2009 | 09:26 PM
eggenz7's Avatar
the only way i know to get the nuts off is to cut it off..cut into with a cuttin wheel till your just about threw it. then get a good cold chisel and give it a few good wacks making it go in the direction to take it off...that should break it loose...i have yet to come across one of those nuts that will come off...and thats using 2 18" pipe wrenches and a 5lb sledge
Old May 2, 2009 | 09:56 PM
itch's Avatar
i use two 2 ft pipe wrenches one on the axle against the floor to keep it from moving one on the nut with a 3ft bar on the end , heat it up red hot and stand on the 3ft extension and cross your fingers, i had to use the cutting wheel on mine the first time i did it
oh and you only need to take apart the sprocket hub side and slide the axle out of the carrier from the rotor side leaving the rotor and nut intact
reassemble with anti-seize on the threads
Old May 3, 2009 | 09:01 AM
opcruzer's Avatar
I had a feeling this was going to be the answer. I had a pipe wrench and about a 4' cheater bar and the bench started moving and I said thats about enough. When we heated it, it got red hot and then I could move it about 1/8th of a turn and that was it and that only lasted about 3 tries and that was enough heat. I hope I can find a new blade for my cut off saw.
thanks guys
Old May 3, 2009 | 11:27 AM
ftwflh's Avatar
I use a drimmel with a cutting wheel then split the nut the rest the way with a chissel
Ean
Dec 19, 2022 08:48 AM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
maxjung
Jul 13, 2015 05:11 PM
Chocobamofo
Jul 10, 2015 07:46 PM
