1999 400 coolant leak, need advice
Old May 3, 2009 | 07:29 PM
Lakeeffectsledhead's Avatar
Unhappy 1999 400 coolant leak, need advice
I bought a 1999 Sport 400 (basically a 4x2 Scrambler), non running, no compression to speak of. I rebuilt the top end by honing, new piston, new rings, new gasket set. I filled it with coolant and after a few minutes of checking everything over for leaks before firing it up for the first time (I had to remove and re-install the gas tank too), I noticed coolant coming out of the stud on top of the head. So I figured I probably didn't clean something up good. Removed the head, cleaned off everything again, put the head back on (double checked that the "UP" was up on the gasket) and filled it with coolant again. This time no leaks. Cool. Or so I thought. I turned it over and it fired right up (grins), backed it out of the garage and rode it around the yard to give it a little test. Stopped and looked it over and I noticed that the exhaust was burning coolant and coolant was coming out of the head studs again.
What's goin on?
Bad head gasket? (just bought it new)
Bad head? (a friend has one laying around that he said I could try)
Bad jug? (god, I hope not)
Tony
Old May 3, 2009 | 07:34 PM
itch's Avatar
someone in the past over tightened the head ,causing the stud/studs to pull up slightly and create a high spot around them that the gasket cant seal letting coolant into the jug ...maybe???
or the head is warped ?? , are you using a polaris OEM head gasket?
Old May 3, 2009 | 07:38 PM
Ok, so if I overtightened the studs, what's the solution? This could be the issue, as I don't have a torque wrench and snugged them up. Do I just take off the nuts and re-tighten them to the right torque?
Tony
Old May 3, 2009 | 07:47 PM
itch's Avatar
IF that is the problem,if. you need to remove the studs and have the top of the jug trued
send it to ritter cycle racing to "take a little off the top" send the head too or i have heard of people using a mirror with some 400 wet and working on it themselves . i chose the ritter option for the one i had done
Old May 3, 2009 | 07:56 PM
I'm gonna throw that extra head on tomorrow and see what happens. If it still leaks I'll pull the jug and take it to the race engine builder down the road. This guy near me used to build all the factory engines for the Honda national moto x team and knows his stuff.
Tony
Old May 4, 2009 | 08:51 PM
Anyone know the torque specs for the studs on the 400 head?
Old May 4, 2009 | 11:04 PM
itch's Avatar
18-20 ft lbs
Old May 5, 2009 | 07:27 PM
hotblooded's Avatar
Which is about the twist of a wrist.
1ArmBandit
55
Oct 14, 2015 09:03 PM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 08:03 AM
Steeldon
Sep 9, 2015 09:38 AM
Kenidah
Sep 7, 2015 07:50 PM
