05 MV7 Hot Light
Old May 3, 2009 | 08:46 PM
Outback31's Avatar
Has ridden Rockhouse and Bearwallow trails.
Default 05 MV7 Hot Light
Been awhile since I've been on. Buddy has MV7 that as soon as you turn key on it flash's hot, even when it is cold sittin in the garage. Seem's to run fine. Doe's not qualify for ecm replace according to Polaris(Carb). Any suggestions'.
Old May 3, 2009 | 09:19 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
My 2006 Sp 450 has a CARB and has the Sure Power Module Some call it a ECM but it;s really a PDM power Dis. Mod.
On on my third one and YES they are know to send a bad reading for the HOT light......
It controls the cooling fan also and there are two solid state circuit breakers in there too!!..........People get mixed up thinking that with a CARB model there is no electronics to control the fan,breakers,temp, lights...etc.....
these are all electronic controlled..........Caper........
Old May 3, 2009 | 10:59 PM
chuck_raduenz's Avatar
check the thermosistor. not shure where it is on yours but a 08 500 is on the left side on the cylinder head. has a 2pin type trailer plug(quick disconnect) it tells what the temp of the engine is. if i unplug my sensor it turns my fan on and flashes hot. found that out one day. it evon turns my fan on when the keys off. i had an issue with the sensor back on my 00 sportsman. it flashed hot and the fan ran all the time. but check it with an ohm meter. 185 ohms the hot light is on at 245ohm the fan is on. id start there. easy check.
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
