800 tranny creeping
Old May 4, 2009 | 09:01 PM
dslanec's Avatar
Default 800 tranny creeping
I have a 07 800. When i come to a stop the machine wants to slowly creep forward still. If I put it in low range it will start moving on it's own. Im sure this has been discussed but i tried the search and did not find a answer. I drove 50 miles today and this is the only problem. It drives great. I will be taking the belt cover off this weekend to have a look. What should I be looking for? My friend has a 500 and said it might be the plastic buttons wore down? The belt was replaced about 500 miles ago and has no issuies that I know of. Thanks for the help.
Old May 4, 2009 | 09:50 PM
UTU's Avatar
UTU
Default creepy
Check the belt alignment belt should be riding in middle of primary equal space from the primary sheaves.(alignment tool works best). Could also be loose or broken motor mount usually the lower....
Old May 5, 2009 | 05:51 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it would either be the ebs bushing, fiber washer in the primary clutch worn out, or it might be the clutch is out alignment which sometimes happens from a broken engine mount as the rubber mount seprerates. it wont be the buttons in the secondary as its a roller clutch.
Old May 6, 2009 | 12:15 AM
contentsunderpressur's Avatar
The idle is not a little too high is it? I had that problem once.
Old May 6, 2009 | 04:50 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
idle should be right around 1200 rpm's much over 1300 and it could creep. imo
Old May 6, 2009 | 06:39 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
There are 2 fiber bushings in the primary clutch, have to replace both, about $10 at Polaris dealer, just did 'em a friends '07 800 X2, cures the problem right away
Old May 6, 2009 | 08:28 AM
dslanec's Avatar
Thanks for the replies. M i idle is about 1150. I do not feel to confident working on the clutch myself. I dropped it at the dealer today. He checked the motor mount right away and it was fine. He should be able to look at it tomorrow and let me know. It is also very hard to shift now as well. He said that is because the one way clutch is staying engaged and keeping pressure on the tran ny. I will upsate when I hear more. Thanks.
Old May 6, 2009 | 12:32 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yea chances are its the one bushing that is the issue. that is the correct rpm that its idling at.
Old May 6, 2009 | 01:13 PM
Hotdogmb's Avatar
My 02 500HO did the same thing and it was the EBS bushing.
Old May 11, 2009 | 10:21 AM
dslanec's Avatar
Well I called the dealer today. They did end up finding out the front motor mount was broke. They ordered a new one that should be here today.They will put it on and hopefully that will fix my issiue. I will keep ya posted.
